Edge 1030 and Vector 2 will not calibrate
I have an Edge 1030 and Vector 2 Peds. While I can add the sensors to the Edge, they will not calibrate. Batteries have been replaced. I have removed the Vector 2 from my device, restarted the device and reconnected the Vector 2 with no change in results. Software on Edge updated again this morning.
Any ideas of what I can do?
  • Hello jayhawk.miller,
    Mount Angle setting was successful?
    Read out the left and right error codes on the edge 1030 @ Vector 2 (sensor connect) and post it here should be 0-0.
    Greetings
    Erik
    0 Former Member over 5 years ago in reply to Erik1503
    Mounting has not changed. They have worked in the past. I thought it might be a software update that messed with it.
    I get no read out....just the calibration circle till it times out.
  • @ 1030 do an alternative  sensor search -> search for any sensor instead of a Powermeter search.
    Spin the crank a few times before sensor search.
    All bluetooth devices except your 1030 should be shut down during sensor search.
    Check the LED flashings at your Vector 2 -> They are error codes -> see your Vector 2 manual
    Maybe a FW update of your Vector 2 with BT PC and Garmins "Vector Updater"
