Edge 1030 starting and suddenly switching off
My Edge 1030 is creating troubles, when switched on it's making the booth but suddenly before having the possibility to have acces to any menu is switching off.
I tried to:
* soft reset
* reset settings
* update software
No matter, it's not working. Can someone advise on how to fix the issue?
Many thanks ciao
  • Connect your Edge to your PC/Mac and move all fit-files in /Activities to your computer. Empty the directory /Activities. Check if that helps.
    If not and you have a SD card installed - take it out and check if that helps.
