Saving waypoints
Is there a simple solution for saving a waypoint while im riding a bike ?
  • Tap on the map. You should see a - and + at the left and right near the top. In the middle, will be a square with a circle in it. Press on the square.
    Then, press and hold on the map at the place you want to drop a pin. You can change the name,
