Hi,
Ive just purchased a 1030 having had a 1000. Its loaded with software 6.30. After past bad experiences with updating edge devices how is everyone finding 7.50?
Thanks
Hi,
Thanks
I have a separate thread about broken TBT. I have discovered that if you start a course and start the ride, when TBT fails to begin if I do a hard reboot (push the power button until the Garmin restarts), then TBT will start working after the Garmin restarts and I resume the ride.
Not sure why my reply was duplicated 3 times. Anyways, like I said, when updating to 7.50 and the latest maps at the same time, the unit crashes when navigating to some POIs. It indicates route calculation errors on some others. If you routinely navigate to POIs you may want to avoid updating to 7.50. Maybe it is the latest map that has problems and not SW... not sure.
My old problems, which where solved with 7.30 came back with 7.50 (segments not stopping, "Time Ahead" jumping and rout calculation errors. But only in segments
