Edge 1030 / iPad / Wattbike
Can anyone help me connect my Garmin Edge 1030 to my iPad, I use the iPad on my Wattbike to control the Wattage in ergo mode.
Thanks
    Install the Garmin Connect Mobile app from appstore and use that to connect the Garmin to the Ipad.
  • Thanks for your help, I have Garmin app on my iPad, But when i click the + icon to add a device, it says starting set up, Then select your device, I then choose garmin edge 1030, Bluetooth is on, i ask it to start, then I get a box up asking to select an Accessory, But there are no choices,
    I am at my wits end with this, been at it for days.
    Any more help would be appreciated
    Thanks
    Can you post a screendump from the Ipad on the "select accessory´s" screen?
  • Not sure how many BT connections the wattbike uses but it's possible you're hitting a limit on the max number of bluetooth devices. Try disconnecting all other devices and pairing the 1030 then.
