I am in US and having the issue with Polar 7 and 10. The only solution is to hard reboot the Edge 1030 and then it will correct the issue. with me the issue starts if i stop my ride and start a new one. The Edge will keep going with the last reading and not change.
read something, Garmin telling they prefer and recommend the use of ANT+ when possible and as last resort Bluetooth
with the H10 this should be no problem given it also works via ANT+
happy & safe sporting
How do i tell H10 to connect ANT+? all that i am doing is connecting it via Edge settings. If i disconnect my H10 and go back to the Garmin Edge, it will show that H10 is disconnected. But my biking profile will still displays a Heart Rate that does not live, but instead the last reading before disconnect. The only things that solves it is a hard reboot of the Edge. Then it will display live data.
BTW - this started happening after the last 2 updates.
you did update the H10 with the latest firmware
check the H10 in the sensor menu
when you see a name with mac address then it is bluetooth
disable the bluetooth paired sensor
search again for a new hr sensor while wearing the H10
Happy & safe sporting
