Physio Trueup working?
I have an Edge 1030 (beta 4.36), and a Fenix 5x (beta 9.1l. Trueup is enabled on both devices, howver none of Edge scores {training state, recovery time, etcl are showing on my 5X.
Does this work for anyone else? Did I expect too much? Have sent report to beta team.
R.
  • Yep works on all my devices Fenix 5X, FR 935 and Edge 1030 under device settings in GCM is the TrueUp option enabled?
  • Yep, it's enabled in GCM Edge 1030 device settings - still not working. I guess that's why they call it beta.
  • Fixed It ! Upgraded from Beta 4.31 to normal 5.00 firmware, reenabled Trueup, everything sync across to my Fenix 5x just like it should. Very pleased this works.
    I have a Vivoactive 3 and an Edge 1030. The vivoactive 3 keeps track of 'active minutes'. Are these supposed to be updated as well now by activities tracked on my Edge? Because they don't seem to be.
  • Make sure you have the latest firmware on both the watch and the 1030 that includes trueup. Then you have to enable trueup on both devices. You also need to enable trueup in gcm under device settings. If just one of those things aren't set, it wont work. Seems wierd that we have to enable it so many places.
    Sploit, I too have a vivoactive 3 and it is syncing my cycling activities to my watch, but just like you it is not counting that towards my intensity minutes. I'd say thats a bug that needs fixed on watch.
  • So, I see you only mention that you have enabled it on 1030 in gcm. If you read my post before yours there is 4 places you have to enable. On 1030, 1030 gcm settings, on watch, watch gcm settings. Make sure you have all enabled.
  • Fully working here. Before I noticed the sync happened, my 1030 measured Ride was available (so as the recovery time and training load) on my Fenix 5.
  • I can see how to setup
    1. On GCM for Fenix 5.
    2. On GCM fir 1030
    I can also see the setting on the Fenix 5, but I cannot see where to setup / see what is set on the 1030. Can anyone help?
  • Well, when the 5.0 update installed on my 1030, it asked me if i wanted to enable trueup on 1030 and I said yes. If you click on "my stats" on 1030, then the arrow in upper right corner for training status it will give you new screen. Then click the menu at bottom right. There it tells me trueup is enabled. Hope that helps.
  • Freud_,
    When my 1030 upgraded to 5.0, a popup asked me if I wanted to enable trueup on 1030, and I said yes (I also had to then enable in gcm). I looked the other day and as far as I could tell, you are correct that there is no place to change this on the 1030 device. There is a place you can verify if is enabled though. In terms of watch gcm settings, it is in the same place as the 1030 gcm settings. You click on device and go to device settings. I have a vivoactive 3 and it is there. It is possible they haven't pushed this out to fenix5 yet on gcm.
    It's very strange the way they pushed this out. I would have pushed the new builds out to each device first without mentioning it. Then push out the gcm changes and then tell everyone about it. That way everything is there ready for it to work. Seems like they did it backwards. I feel like gcm is where trueup should live anyways. Shouldn't really require any changes at all on the devices.
