Mine was on 2.4 last I checked which was last week so if you are on 2.5 it means there has been an update. It seems the numbering of the versions is different for each region. Since when are you on 2.5 ?
i didn’t check the version when it was delivered 2 days ago. But there was map update yesterday, so my unit might get updated to v2.5 yesterday. I hope you’re right that diff region has diff version number, otherwise it is so unfair not to get latest update.
I always have problem connecting my unit to connect to my iPhone SE at same time with my BT headset. In case anybody having same problem, the workaround is to connect Edge unit to phone first then connect the BT headset.
Well 3.5 APAC is a disappointment: over a 2 hour ride, 1030 crashed and repeatedly lost the connection with Varia radar. I am putting it back in its box until the next release.
Updated to 3.7 APAC and it crashes for every ride... The guy from distri says that it is a firmware issue and Garmin is working on it. Better be quick, I don't want to think about having the latest bike com and not able to use it.
