FR 955 usability improvements for quick controls
Fr 955 fw 12.23
The quick controls (hold power button) is a bit annoying if the watch is in airplane mode and/or battery saver mode. If you wish to enable Wi-Fi to do a quick sync, you have to first disable battery saver and airplane mode, and then you can turn on the Wi-Fi.
it would be much more user friendly if you could just enable Wi-Fi, and then the other modes would be automatically disabled. It would save a lot of button clicking. So just change the current “warning” to something like, “enabling Wi-Fi will disable battery saver, ok?” ( the same goes for the hot key)
then to really make it user friendly the previous modes should be re-enabled after Wi-Fi is turned off.
Or the best solution for my use case; just have a quick sync control that disables airplane/battery saver, turns on Wi-Fi while syncing, and re-enables everything after a successful sync.
