Today I checked historical running data on temperature and surprisingly found that temperature recording on run profiles has been stopped since V12.20 Beta upgrade, and there is no temperature data on V12.23 as well.
Do you have the same issue?
I have a Tempe sensor too, but I only use it for hikes. However, it seems that this change assumes you use it for all activities (even open water swimming!). If you're not paired, it doesn't record anything - I would expect it to default to the internal sensor. Anyone else seeing this behaviour?
I had already posted this behaviour 19 days ago in the beta bug report forum. Please vote for it there.
forums.garmin.com/.../temperature-data-and-graph-missing-in-run-activities
"If a Tempe is paired with the 955, you can‘t disable tempeature recording.
And if the tempe is not connected, there will also no temperature recorded. Before this beta temerature was always recorded. If the Tempe was connected, it shows the data of the tempe, otherwise the data from the watch."
