Does anyone else's start/stop button seem more "shallow" than the other buttons? Seems more shallow and there is less of a click when pushing the button - not sure if it's just my watch or if it was built like that intentionally. Thank you!
My first one was the other way around, it became 'deep' after a few days of use on start button. I had to press harder to order to assert the button. A regular press with a click won't assert 8 out of 10 times. the exchanged one appears normal now. I worry that the button quality on the new watch isn't the best.
I have had the same on both Fenix 5+ and fenix 6, nothing new here. The "solution" was put it in hot water with some mild soap and soak it for 30 minutes, and that helped . The solution was provided from Garmin Norway, guess it`s universial.
