Solar on the 955 is BS?
I left my 955 solar in the meddle of the Florida sun at 12pm for 60 mins and it didn't even go up 1% it actually went down 1%
Am I the only one?
  • On my Instinct 2 Solar I can charge the battery by solar, but Garmin claims more battery life for the Instinct 2 that for the Forerunner 955. I think the solar area is also bigger, but not 100% sure.
    Seeing your question here I've ported my Battery Guesstimate Widget to Forerunner 955, it should show you the battery changes more accurate: https://apps.garmin.com/en-US/apps/572b8232-7fb6-4e4f-a938-2395d0df3c7c
    would be interesting to know if you can make the solar actually charging you watch
  • thanks. i may give a whirl although i think i'm content now with my usual faces using up 5-6% in general. thankfully, i haven't had any phantom losses overnight as others have observed due to my minimal fields and only using Garmin HRMs as an ANT device.
