I have found 2 possible bugs with the climb pro function
- If you have a course loaded and climb pro is showing that there are 2 climbs, than after you pass the first climb you exit navigation and then load the same course (you are located in the middle of the climbs) it will show the distance to the first climb that you have passed and after you pass the second one it updates and says that there are no more climbs left. So climb pro will not pop up for the second climb (hope that makes sense)
- Climb detection settings does nothing (does not matter what setting I have, it only shows big climbs)
Can someone with a FR955 help me and verify this?
I did not test climb pro when running, this bugs I've found when cycling with the bike activity
