Hi
I have problem with maps.Ive uploaded some free OSM maps and always one of them is not available to select. As i see that one map i set as preselected - cant select/unselect it, but its imposed on the board when i open Map screen. And i can see that map in Maps settings and its size, but not on the list in maps which i want to select. Map affected by this problem seems to be randomly selected (or i dont know the rule). What may be the cause?
And one more question - is it good to use two maps of the same type at the time? Both have their pros and cons, i want to use them complementarily. Can this solution cause any problems?
Greetings!
