Since I got my 955, I cannot edit the percentages of heart rate zones. It allow me to enter a value but never saved.
Same behavior from the watch, and from Garmin Connect mobile.
Anybody else with same behavior ?
Thanks.
Thanks.
All,
We do have some other reports of this and are currently investigating. When we know more, I'll be sure to post updates to this thread.
All,
We believe that we have a fix for this report that will be rolling out with the next software release for this device. While I do not have a timetable for this release, I will be updating this thread…
All,
We are in the process of releasing 12.23 production software. If you experience this battery drain after installing the 12.23 sw update, please start a new thread.
Oh for sure, just confirming it's indeed a bug...
It seems to use the base zones btw, editing those also seems to edit the running ones. So that might be a workaround (maybe need to remove the running…
Same in my case, but without doing anything. And for the second time since my last post 5 days ago. All zone settings, default and sport specific have been reset without any acttion from my side. The scheme is similat for general as well as for sport zones: BPM is replaced by %HRMax and zones are set as basic percentage, i.e. 50, 60, 70, 80 and 90%of MaxHR, while MaxHR is taken from general settings (MAX, LT, Rest) depending on the type of activity (general or sport specific).
The above have happened twice, with two days span. YES , IT'S ANNOYING
The bug wasn't resolved during beta-testing, and moreover, there wasn't ANY response from the support/dev team in that bug-thread whatsoever.
Garmin-Kevin could you, or anyone from your team, finally pay attention to this bug?
Everything that was discussed in this thread is still valid, please check this finally out.
If you need any permissions to use my data for troubleshooting - take it, but fix this damn bug!
I also thought that this was resolved but appears it isn't.
What seems to work:
on the other hand:
I suspect that the runs conducted before the watch re-created a running profile are correct, and those after are not. I have deleted the running profile as before... guess I just have to check before each run?!
This continues to be quite annoying and and impacts the recovery time/training readiness features to the point that they are not very helpful.
