Temperature sensor on Forerunner 935 is not giving any readings
What does the temperature widget screen show exactly? Same for the barometer widget. And what have you done to troubleshoot the issue already? (restart , reset to factory defaults)?
The built in temperature sensor is notoriously inaccurate anyway. It always reads significantly higher than the real temperature. The only time I get accurate readings is on swimming activities for water temperature. Otherwise if I care about logging the real temperature I connect an external Tempe sensor.
They show nothing all temp and bark widgets
Which external temp can we use ?
That's not enough information unfortunately. You have a better chance of someone being able to help you out if you post a picture of the temperature and barometer widget displays, and what the result of a restart or full reset to factory details was.
Thanks for advice . I will try factory reset as suggested
