Skiing activity does not work on my Forerunner 935. I'm starting, I wait until the GPS is green and I press Start. It display Pause, andI after that nothing hapend (I did some descent and not even starting the record). The skiing activity do not appear even when the auto run feature is used. If I run, walk or bicycle, they all work, but the skiing is not. What can be done?
Certainly odd, I can't confirm that (I ski quite a lot, and it works consistently for me - granted, only twice on the 935). 1) what firmware are you on, and is it fully up to date? 1.5)Try power cycling the watch (hold the light button to turn off) 2) try deleting and re-creating the ski activity, just for kicks. 3) soft-reset the watch. 4) hard-reset, wiping all data and starting fresh.
It worked for me at least some time ago (maybe december). Not sure which FW it was on - either FW11 or the previous one (10.something). No issues similar to what you desribe - it just worked.
In skiing mode the start of record is triggered by pressure increase (descend). If barometer port of your watch is not working properly (e. g. plugged or damaged) the record will not start. Therefore I would check the altimeter functionality first.
I have tried it multiple times and it does not work. It will work for 2 seconds and stop. the Elevation will work. i ended up switching to MTB (mountain biking) and that worked great. Gave speed, elavation and heart rate.
