I am using Forerunner 73XT version 9.80.
I have set up an audio prompt telling my HR-value each 3 minutes. However the value in the audio prompt is not equal to the value on the display of the watch - and yes, I have tried both my installed data fields and the default HR-display.
The HR value on the watch can be at 175 while the HR value in the audio prompt often is much lower eg. at 160.
When I look at the charts in Garmin Connect after my run it seems like it is the lower value that gets recorded.
Have any one of you experienced something similar and do any one have an explanation for the reason and even better a solution for getting the value identical and correct?
Currently I do not know which value is the right one - however I think the lower value seems too low so I would expect the high values would be the right (even though it seems to be the low value that gets recorded).
BR,
Ole
