Watch reading "No HR" It was working yesterday and I have made no changes to the settings.
HR monitor is in the "on position" in the Device Settings.
Usually you start a chat or call. support.garmin.com/.../
I've had the same problem recently. I usually wear an HR strap (which works fine), but when I've gone without that, seems the wrist HR no longer works, despite being turned on in Garmin Connect. Odd.
Yep same here! Only started having the problem after recently starting to use a strap.
use a strap
Which strap are you using?
