Hi
Did garmin remove the feuture to save and Calibrate the treadmill distance after a treadmill run in the latest firmware?
/L
Hi
/L
What sensors do you have paired during these runs?
I have it figured out now. Originally go far enough and now I have foot pod and need to get out on an outdoor track to calibrate the foot pod.
thank you
That's correct, as the 645 will not allow for the Save and Calibrate option when using a footpod.
Why can't we calibrate when using a Foot Pod?
Because you should calibrate your footpod (if it needs) and not the watch’s accelerometer
That doesn't actually work. My foot pod sensor has Auto Calibrate enabled and it's accurate on outdoor Run activities. But distances are always too short on Treadmill activities.
