Hello,
My 645 (no music version) freezed today.
Its the first time I see this, it never happened before.
I'm sure firmware update 5.90 is causing this issue.
Any suggestions garmin to fix this?
Hello,
You are not alone.
Same happening to me. Twice now, since it automatically updated to 5.90. Freezes after workout is saved, with light on (so it can exhaust my battery faster?). Was fine before 5.90.
Before 5.90 I never had a problem and I train every day. now with the 5.90 when I save the third workout on the same day the clock freeze. the watch works properly for one workout a day. If Garmin does…
When and will it fix this freezing issue as you have stuffed up a watch that has worked flawlessly up until now I have switched from Polar back to Garmin and withing 2 months I am having issues you created with software its not good enough to release updates that cause problems.
