The walking activity from my forerunner 45, disappeared and I can't add it through the app, does anyone have idea on how to add it again? Thank you.
I had a similar case, only I lost the ability to use Bike.
I connected my watch to my computer and checked the Sports folder.
There was no CyclingBike.fit file. And after synchronization the file did not…
My watch lost the "Other" activity. I checked as below and indeed the .fit file was missing. I borrowed my friend's Forerunner 45 and copypasted the .fit file to the Sports folder and this at the moment…
I have the same issue, I have tried multiple times adding through the App, or through teh website. It apprears as a 'displayed activity' but does not appear on the watch -
There was no CyclingBike.fit file. And after synchronization the file did not appear.
But what is in the folder at the factory settings:
I think in your case the WalkingWalk.fit file has disappeared.
I found a solution here that seemed to work for me
try the last comment:
“In case anyone is having problems trying to change the display activities for a forerunner 45, the only way I could get it to change from run, treadmill, cardio, indoor track was to reset the watch. This is done by:
It was quick to set up again via the connect app and bluetoothing the watch once more. I then set teh activites to those i wanted: run, bike, walk and it worked after sycing
Hope this helps!”
Thank You Anrik.
The "WalkingWalk.fit" file was indeed missing.
I executed the reset, and added my watch - as if it was a new device - to my Garmin Connect app, et voila, it works as desired again.
Thanks for the trouble!
That worked for me, thank you for taking the time to post!
