On Garmin connect my speed chart is completely flat. When loaded onto Strava it’s showing correctly though. Is this a big on Garmin Connect or on the watch? Any way to fix it?
Here it is.
There is no Speed Data in the File.All Zeroes
Possibly you have a Speed Sensor on your bike paired to the device. The Speed Sensor Might be Faulty.
You can Manually Download GPX from Strava and Manually Upload to Garmin Connect. (Do Not Download Original)
chunk#29 - fit_data - record (loc#7 glob#20)
chunk
index 29
offset 790
size 23
header
local_mesg_num 7
time_offset <none>
is_developer_data no
global_mesg_num 20
fields (9)
name timestamp
value 2021-03-13T19:51:32+00:00
units
def_num 253
raw_value 984599492
name position_lat
value -36.87806046567857
units deg
def_num 0
raw_value -439972399
name position_long
value 174.7390045132488
units deg
def_num 1
raw_value 2084717527
name distance
value 0.04548
units km
def_num 5
raw_value 4548
name enhanced_speed
value 0.0
units km/h
def_num 73
raw_value 0.0
name speed
value 0.0
units km/h
def_num 6
raw_value 0
name unknown_88
value 300
units
def_num 88
raw_value 300
name heart_rate
value 104
units bpm
def_num 3
raw_value 104
name cadence
value <none>
units rpm
def_num 4
raw_value <none>
Strava Calculates It from GPS Location Data. (Does Not Need Speed Info)
If It's Done this more than once then.
I suggest a Reset on the Watch or Contact Garmin Support.
www8.garmin.com/.../GUID-72565816-D3FF-4861-9BD0-7E3C80D9E1D3.html
You're Welcome.
Here is a record with good speed Info and heart rate but no cadense.
(My Ride This Morning)
chunk#7105 - fit_data - record (loc#7 glob#20)
chunk
index 7105
offset 164371
size 23
header
local_mesg_num 7
time_offset <none>
global_mesg_num 20
fields (9)
name timestamp
value 2021-03-18T07:51:05+00:00
units
def_num 253
raw_value 984988265
name position_lat
value -26.13177638500929
units deg
def_num 0
raw_value -311764236
name position_long
value 28.187096072360873
units deg
def_num 1
raw_value 336285155
name distance
value 40.30143
units km
def_num 5
raw_value 4030143
name enhanced_speed
value 18.0972
units km/h
def_num 73
raw_value 5.027
name speed
value 18.0972
units km/h
def_num 6
raw_value 5027
name unknown_88
value 300
units
def_num 88
raw_value 300
name heart_rate
value 148
units bpm
def_num 3
raw_value 148
name cadence
value <none>
units rpm
def_num 4
raw_value <none>
