I was unpleasantly surprised by the way the watch displayed a navigation curve of about 44 km in length, with 1671 points (19 of which were duplicates) on the route, i.e. <trkpt> elements in the GPX source file - unfortunately, it cannot be attached here. There was a significant deviation in direction at the start and in several other places the turns were "cut off".
The Czech support recommended that I divide the route into maximum eight-kilometer sections of about 300 points, which seems very impractical and unusable for estimating the arrival time at the destination (ETA). The support did not want to tell me under what conditions this distortion occurs. I noticed that in this case the watch probably reduced the sequence of points by selecting every three and a half points (they took this half as the middle between two neighboring points).
I honestly don't understand why this reduction is performed when the watch is able to correctly display (with a black line) a significantly more detailed, actually traversed route of this activity with 5553 points (exported via the Garmin Connect website). I understand that for some navigation calculations (e.g. checking for deviations from the route or estimating ETA) the watch is suitable for a simplified route, but for displaying the navigation curve they can perhaps leave the points unreduced.
Moreover, the Garmin Connect web application, into which I import the GPX file to create a route and then upload it to the watch, does not warn about the reduction in any way, or does not perform any more sophisticated reduction (e.g. Douglas-Peucker) itself, if it were really necessary. Without precise knowledge of the watch's limits for unreduced display, I cannot externally edit the source GPX myself.
Garmin, would you please comment on this? And do other users have any experience with this?
Thank you.
