Garmin Forerunner 255 – GPS Issues
Hi everyone,
I’ve been having trouble with my Forerunner 255’s GPS for the past week. It suddenly stopped finding satellites when starting outdoor activities like running or walking. Until then, it worked perfectly.
I tried restarting the watch, syncing with Garmin Express and Garmin Connect to refresh satellite data. Oddly enough, it worked yesterday and I completed a run. But later in the day, it failed again.
During today’s workout the signal even dropped mid‑activity and hasn’t come back since. Sob
Now, it just keeps searching without locking onto GPS – even after 30 minutes under clear sky. It’s very unreliable and I can’t figure out any pattern. I’ve tried everything except a factory reset.
Anyone else had similar issues? I'm on software version 23.20. Would really appreciate any suggestions!
  • I only connect the watch to the phone something like 3 times per year, and it gets a GPS fix in around 10 seconds. It always has, except for when I am close to tall buildings or standing under a tree.
  • I've had exactly same issues with my F255, either not getting GPS or dropping GPS mid activity.
    During May/June 2026 I was ready to throw the watch in the bin, as nothing would make it work reliably. It was hit and miss.
    July/Aug 2026 it oddly worked perfectly again. I didn't change process, it just appeared to be working better.
    Come Sept 2026, and I'm back with GPS problems again.
    I've tried doing the sync with Garmin PC app which I probably do once a week now. I can't say for sure if that fixes things or not.
    On my run on Sunday, GPS locked percectly with in 10 seconds of turning to Run mode, so I thought everything would be great. However, 2 hours into the run, GPS just stopped and nothing was recorded for the final 1 hour.
    It's the inconsistency which is most frustrating, as you just don't know if it will work or not.
  • Do you have the music model with wifi configured?
    I have the non-music FR 255 and have always had this issue that satellite fixes are slow and less reliable if I don't let it sync long enough with Connect mobile every week. But in my case, it showed "expired" or "missing" in the About screen too.
    I usually have bluetooth disabled, so I have to remember to do enable it for 30-60 minutes (in one big block, not moments here and there).
    As I understand it, the watch has to decide to poll/fetch the ephemeris, and Connect is just acting as an internet proxy. So this request could also go over wifi.  It doesn't seem to get triggered immediately upon bluetooth reconnection or sync actions. Instead, you have to have connectivity available long enough for it to work when the watch independently decided to make the request. :-(
  • Personally I have standard FR255 with no WIFI.
    I keep Bluetooth on all the time, however I have noticed that on the occasions it has failed have been when I do early morning runs. When I look on Connect app on the phone, I can see that it hasn't synced with my watch since the day before. (I can see, as HR and sleep data over night isn't showing.)
    If I do an early morning run, as long as I remember, I open up the connect app on the phone and force a sync to the watch. This seems to increase the probability of having no issues, but doesn't work all the time.
    I was making assumption that forcing a sync it would force the ephemeris data to get updated, but maybe as you suggested, the watch makes the decision if it needs to pull new data from internet or not.
  • Yes, I have the Music version with WiFi. But I do not have auto sync on, so I connect manually once per day or so.
    I remember back in the days with other Garmin watches on bluetooth, where sync seemed to go quite fast on the front screen of the connect app. But if I went to the device screen, there was a longer progress bar. If I only used the progress bar on the front page, it would not download new firmwares and other stuff that took more time.
  • The sync action via the watch control menu goes about the same speed as the Connect sync. It only seems to be about the FIT data and doesn't include firmware, CIQ, or ephemeris status.
    The Connect app sometimes shows firmware download, and the Connect IQ app shows some status about CIQ updates.
    Nothing seems to correlate with ephemeris updates except leaving it connected long enough for the System -> About screen to show an updated status.
