Perché rimangono i tre led della frequenza cardiaca ancora accesi anche dopo aver tolto l'orologio dal polso?
Grazie
Grazie
If you put your watch on a table and don't move it, then the leds should be off.
But if you move it, even when not on a wrist, then the leds will turn on to check, if nothing to read, then leds will quickly switch off. If you keep moving it, then the leds will turn on again.
If the leds are always on, then automatic switch is broken. There were similar threads: Led not switching off when taking watch off.
In such case, you can only manually turn off Heart Rate setting when you're not doing an activity. And turn it on again when you need it. Activity -> Menu ˅ (down) -> Settings.
