Hi,
trying to setup a vortex a friend gave me…
- using Tacx app on iphone
- connects instantly
- go to calibrate
- no mph/power registered, sticks at 0
- try to connect to Zwift and trainer is not showing at all
Any ideas?
thanks in advance,
Ed
Hi,
Any ideas?
thanks in advance,
Ed
This is exactly what is happening to me. Also just started happening when I updated the Firmware!! Any ideas anyone???
Same is happening to me. Please help garmin!
Same for me too! I bought the trainer 2nd hand and had seen it working. I'm wondering whether it's a firmware issue as it updated when I connected it to the Tacx Training app.
When I try to calibrate the MPH is greyed out, is that the same for eveyone else?? This is different to the Tacx Flow I have which is white even when it isn't going.
Can the firware be rolled back manually to check maybe?
First, check this:
https://support.garmin.com/en-US/?faq=faU1VcypD12GKsn0NMx9pA
The old version of the firmware can be installed using the old versions of the Tacx utility app:
https://apkpure.com/tacx-utility/tacx.android.utility/versions
Two ways to use the Tacx utility app.
First way. Through this firmware file:
http://download.garmin.com/support/Fitness/Tacx/Flux_S/restore.tacxfirmware
Use this instruction by analogy (keep in mind that Neo 2 and firmware for Neo 2 are mentioned there):
https://tacxfaqx.com/knowledge-base/neo-2-firmware-0-0-18-rollback/
The second way. Install such an old version of the Tacx utility app, inside which there is the required firmware version.
