Hello Garmin/Tacx Support,
I am considering purchasing a Tacx NEO 3M and would like to confirm compatibility with my bike before ordering.
My drivetrain/setup is:
- SRAM RED XPLR AXS 1x13
- RED XPLR Full Mount rear derailleur
- SRAM Rival XPLR XG-1351 cassette, 10–46T, 13-speed
- SRAM Flattop chain
- 44T front chainring
- 12x142 mm rear thru axle
- ROSE Backroad FF
I would like to install the XG-1351 cassette on the Tacx SRAM XD-R freehub body and use the real SRAM drivetrain and physical shifting — no Zwift Cog or virtual shifting.
Could you please confirm:
- Is the SRAM XG-1351 10–46T 13-speed cassette compatible with the Tacx NEO 3M using the Tacx XD-R freehub body?
- Is the SRAM RED XPLR AXS 13-speed Full Mount rear derailleur officially compatible with the NEO 3M?
- Is there sufficient clearance between the Full Mount derailleur and the NEO 3M housing/axle adapter across the complete 10–46 cassette?
- Are any additional spacers or adapters required?
- Will the cassette position/chainline allow normal AXS indexing without having to readjust the derailleur when switching between the rear wheel and the NEO 3M?
I noticed that the current NEO 3M documentation explicitly mentions SRAM 12-speed XD-R, but I could not find confirmation for the newer SRAM XPLR 13-speed drivetrain.
Thank you very much.
