Tacx Neo 2T cadence spikes and resistance changes
Hey,
after reading many posts with cadence and/or resistance change problems with the Tacx Neo 2T, looks like many users are still having this problem.
And just want to say that i have this problem too, may it helps if there are more uf us.
I have it in zwift but also in the Tacx App, and it gets worse at higher wattage.
Still was in contact with garmin support - giving them many many examples - but without positiv result at the end. They more gave me the feeling it is my fault.
For me 2.6.0 works better than 2.7.0. I still have sudden resistance changes with 2.6.0, but with 2.7.0 it is almost unuseable.
Hope there is a solution soon Disappointed
  • I see a similar pattern (cadence down on standing up, then higher power needed to get the resistance down on erg mode) when I stand up for a couple of seconds while riding. Looks OK to me.
  • This is happening to me as well.
    I haven't done thorough testing/research but I have a suspicion it has to do with a combination of factors.
    1) Race mode enabled within the Tacx Training app
    2) Tacx Neo Road Feel Enabled within Zwift
    3) Riding on cobbles in Zwift
    4) Putting out high wattage and cadence (around 100rpm+)
    Did you experience the cadence dips/spikes under similar circumstances?
  • i have the same issue. in Zwift, but also on MyWhoosh with BikeControl...
