Heat rising from top vent after workout – normal?
Hi. After a workout I noticed a lot of heat coming out from this area:
Is this normal, or is there something I should check?
  • It is normal, especially on higher watts, lets say 1h@300W   , on 150-200W just a minimal heat is generating , the upper fan is blowing out the air (the lower one is sucking in), usually the fans are working after a hard workout for 5mins minimum (with full speed then the rpm goes lower)
  • It is normal for that part to be warm after a workout, can you hear the fan making noise to cool down? If it isn't making noise, please update the thread!
