Tacx Neo 1 virtual shifting
Hello,
As an owner of the original TACX I am feeling a bit left out by the lack of support for virtual shifting.  Garmin, are there any plans to make this available.  There is no technical reason for it not to work and several developers have made workarounds.  This feels more like planned obsolescence rather than anything else. Please advise. Also I know this is the Tacx 2 forum but that is only because the 1 was archived.
  • totally different comm chip than the '2 family so they didnt want to write a different firmware for an even older, discontinued model. the old Neo 2 users are lucky because it has same components than the 2T (which is still purchasable) and this is why they got it (with the unified firmware) .
  • So Garmin, there are definitly no plans to support virtual shifting for the TACX Neo Smart T2800 in the near future, or this will never happen?
    Thanks
  • The solution is here: https://github.com/Berg0162/Tacx-Dongle-VS
    It works fine with Zwift and Rouvy.
  • This is brilliant. Thanks
  • Does this also works with MyWhoosh?
  • MyWhoosh uses a different method to simulate gear change.
    Zwift and Rouvy use the Virtual shifting library (Zwift propietary).
    Tacx released a firmware upgrade for recent Tacx trainer (not for Neo1) for compatibility with this. To use with Neo 1 you need Tacx-Dongle-VS.
    Mywhoosh instead, send a modified gradient to the trainer according to virtual gear selection. For this reason it works even with Neo 1 as is (you don't need anything else).
  • I'm currently using the combination of hardware: Tacx Neo 1 and Zwift Play controllers with software: MyWhoosh and the BikeControl app. It works, but after a while it looks like shifting is sort of mixed up. So what first was shifting to a lighter gear changes to heavier gear and vice versa.
    I was hoping that perhaps this Tacx-Dongle-VS could help to get virtual shifting right...
  • I don't think so. It works only with native commands of Zwift VS library, not used by MyWhoosh.
  • It's simply incomprehensible to me that one TACX Neo model can be compatible with virtual shifting while another model cannot. The entire simulation can be handled within Zwift. The original Neo can perfectly well respond to software instructions to increase or decrease resistance, and that's all you need to simulate a harder or easier gear. Requiring firmware changes specifically for this simulation is just bizarre. It's as if only the newer TACX Neo models were compatible with adjusting the rider's weight in Zwift. I’d love it if someone could explain to me why it’s like this.
  • There are no planned updates for older NEO models (NEO Smart (1) and some older NEO 2) at this time
