Hi, how reset or set the barometer on garmin venu?
The barometer will be „reset“ with GPS. Start an activity and once the GPS signal is found wait for 30 sec. The GPS height reading will then used to calibrate the new height at the current pressure. Manual adjustment is not possible.
Perfect!
Thank you.
New to Venu. After GPS signal was found I was waiting for minutes and my height reading is still wrong (330m instead 280m). How to fix that?
