Venu 4 latest 17.39 firmware : during Pool Swim/Open Water Swim, water sporadically activates the left-swipe Music Playback Controls even while Touch Lock is ON
Thanks for the post, underoaking . To better understand what's occurring, could you please check and let us know:
If possible, please also share screenshots of both the swim activity settings and any Focus Mode associated with the activity. This will help us compare the configuration and determine whether any settings may be contributing to the behavior. **
Thanks for the response!
- Touch lock is auto-enabled in Pool swim and stays enabled during the swim
- Touch lock is also enabled in Activity Focus.
Screenshots are attached.
Touch lock stays enabled during the whole swim without interruptions . It protects against most of the touches. The only problem is that swiping to the left-right is still accidentally activated by water, despite the Touch Lock staying on. As a result, the music player is temporarily activated (for 5 sec or so), and then the data screen returns to the usual pool activity. However, this behavior is very annoying -- it prevents seeing data while swimming.
So in a nutshell, touch lock is not good enough against water.
Thanks for the screen grabs and clarifying info, underoaking . I'm going to send you an email here shortly to gather some additional info/files, so please be on the lookout for that.
Anyone else experiencing this same thing, please comment but also bookmark this thread as we will post meaningful updates here.
