ANT+ Weight Scale Display is able to upload weight, body fat, etc. to Garmin Connect?
https://play.google.com/store/apps/details?id=com.quantrity.antscaledisplay&hl=en_UK
ANT+ Weight Scale Display displays the body composition readings that are transmitted wirelessly from ANT scales.
The app is free to try: test weight and body fat percentage to check communication with the scale.
Once you know it works fine with your scale, you can buy the premium version. The premium version displays all the measured values, as well as export these values to Garmin Connect (all values), Strava (weight), Fitbit (weight and fat percentage), Sporttracks (all values) and TrainingPeaks (weight, percent body fat, muscle mass, BMI, BMR and water percent).
It works with built-in ANT+ chip devices (ANT Radio Service is required) and using ANT+ USB sticks (ANT Radio Service and ANT USB Service are required).
Help translating the app into your language: localize.quantrity.com/.../5
Compatible products:
- Tanita BF-2000 IronKids
- Tanita BC-1100F
- Tanita HD-400F
- Tanita HD-351ANT
- Tanita BC-1000
- Tanita BC-1000plus
- Tanita BC-1500
- HMM SMARTLAB FIT+
- HMM SMARTLAB FIT W
- A&D Medical UC-324ANT
NOTE: if ANT Radio Service or ANT USB Service are not available for your device in Google Play, you can try installing them from the official ANT github:
github.com/.../Services
WARNING: Garmin Connect eventually stops working. It is not an app's fault, it is Garmin Connect service. Even if you try to upload an activity within their website in that moment, it will not work. In such case, wait until the service is restored and upload the body composition readings from the History.
- Tanita BC-1100F
- Tanita HD-400F
- Tanita HD-351ANT
- Tanita BC-1000
- Tanita BC-1500
- HMM SMARTLAB FIT+
Someone of you tried? who uses one of the Tanita scales?
