Keep loosing sync / pairing and having to re-pair
twice now in the last week or so the ISM has failed to connect / sync to Connect (on iOS). It seems like the ISM has completely reset itself or something.
I end up having to remove it from Connect and re-add it, then it'll work again, but lost that nights sleep data.
Not sure if this is related, but it will seemingly randomly buzz 15-30 mins after putting it on some nights. I don't have any alarms set.
Any ideas what's going on, or how to fix it?
  • I've expreienced the issue of losing my sleep data before. This morning it happened again; the device started flashing purple, so I had to re-pair it, and I lost yesterday's sleep data in the process. The device is completely unreliable.
    • When did you first notice that the device unpaired/you lost data? --> I first noticed the data lost a while ago. It happens occasionally. The most recent time the device unpaired was today.
    • Is this daily that the device disconnects? --> No.
    • What steps do you have to do to get the device working again? Do you just need to unpair/repair? --> I have to re-pair the device to get it working again.
    • Does the device flash purple when in pairing mode? ---> Yes.
    • Are you using an Android or iPhone? ---> iPhone
  • Thank you for the updated responses! I am in the process of getting emails sent to you so please be on the look out that you received it. At this time we have enough reports for our investigation, but if that changes and/or we have a new update we will post in this thread!
  • I lost sleep data (as in no data recorded) after charging the ISM and then immediately wearing it to bed. Mind you I did not follow my usual routine of syncing my FR265, taking it off, syncing the ISM and feeling it vibrate, etc.  And the ISM did record properly last night.  I am optimistic that it was a one time glitch.
  • I have the same problem, I’ve noticed the battery discharges faster thank the watches and have to recharge about every 3 days, even with a good charge I sometimes cannot connect to Garmin connect, I’ve restarted my iPhone, the only th one that works is to forget the ISM and re-pair and then loose the nights data
  • Happens to me two times. The last 4 months. Should not happen
  •  With regard to the battery concern that you mentioned, it's possible that this is related to the main sync issue outlined in this thread. About how long after you wake up do you sync your Index Sleep Monitor with your Garmin Connect account? Are you removing the sleep band and placing it on a stationary surface near your iPhone, with the Garmin Connect app either opened or running in the background?
  • I try and sync shortly after waking up, usually within an hour.
    I have the following products and do not have any issue syncing these to Garmin connect.
    Descent Mk2I watch
    Descent X50i dive computer
    Index BPM
    Index S2 + Scale
  • I am getting about five, maybe six days out of a charge.  There is usually a drop of a couple of battery percentage points between when I take the ISM off to when I put the ISM on.  Somewhere in the threads here I documented my findings.  Once my ISM goes down to zero and I charge it back up again, I will make a note of what the battery drain is like.
  • This is happening for me too. The ISM will randomly end up in synced from my phone/Garmin Connect. It needs to be re-paired to resolve this, and will often result in the loss of a night's sleep data.
    What I noticed during the re-pairing process is that the ISM has changed Bluetooth MAC address. This explains why it has lost connection, but why or how it is changing the MAC address remains a mystery to me.
