Keep loosing sync / pairing and having to re-pair
twice now in the last week or so the ISM has failed to connect / sync to Connect (on iOS). It seems like the ISM has completely reset itself or something.
I end up having to remove it from Connect and re-add it, then it'll work again, but lost that nights sleep data.
Not sure if this is related, but it will seemingly randomly buzz 15-30 mins after putting it on some nights. I don't have any alarms set.
Any ideas what's going on, or how to fix it?
  • I tracked the battery usage for my ISM and it aligns with the seat of my pants thinking of getting five to six days of battery before needing another charge.  Here is what I recorded.
    Starting Charge Ending Charge
    100% 88%
    84% 73%
    68% 53%
    52% 41%
    39% 23%
    22% 7%
    I am bummed about the percentage loss between ending charge and starting charge, but there is not much I can do about that.  I take the ISM off, leave it standing on edge in a big O format so nothing is touching the sensor.  The ISM sits on my end table in a dark room.  I do not know what else I can do.  Seems like the ISM stays on/connected for a while after I take it off.
    The ISM has stayed paired with my Iphone after charging.  Hope some of this helps.
  • Running into my second time with the ISM losing connectivity - it's getting very frustrating.  It's not just that I lose a day of sleep data - it's that I have to go through the whole setup process again, re-create all of my alarms.  I mean - you really need to fix the whole losing connectivity issue, but also, why are all the alarms lost when the bluetooth address / serial number hasn't changed?
    When did you first notice that the device unpaired/you lost data?
    Just noticed it last night - I charged the ISM before bed and noticed that it wouldn't sync up with my phone so I don't know what the battery percentage was before I went to bed, but I sort of hoped this problem wasn't happening again.  The battery level was not that low before I went to bed - I charge the ISM every 3 days and try to keep the battery level between 30% and 80%.
    Is this daily that the device disconnects?
    This is the second time that this has disconnected since receiving the ISM at the end-of-May 2026.
    What steps do you have to do to get the device working again? Do you just need to unpair/repair?
    I need to unpair/re-pair, but then I also lose a day of sleep data, have to recreate all of my alarms.
    Does the device flash purple when in pairing mode?
    Yes it does.
    Date(s) of the occurrence
    Last occurrence was Sept 11 2026; not sure of the previous occurrence, but it was a few months ago.
    Whether sleep data was missing
    Sleep data was missing.  Alarm did not go off either.
    Whether the device required re-pairing or showed as disconnected
    ISM shows up under Garmin Connect as expected, but can't connect.
    In Android Settings, ISM shows up as expected, but can't connect.
    Phone model
    Google Pixel 7
    Phone OS version
    Android CP2A.260705.006
    Garmin Connect app version
    5.29
    Whether the behavior occurs consistently or intermittently
    It happens intermittently - this is the second time this has happened since I purchased the ISM
    What I tried this time
    I tried just removing the ISM from within the Android Settings; I didn't remove it from Garmin Connect.  When I started Garmin Connect again, it determined that the ISM wasn't paired and so started the pairing process.  No problem putting the ISM into pairing mode.  Unfortunately, all of the alarms were lost again, so have to recreate those.
    Note re USB File Access
    I don't believe that disabling File Access Over USB resolves this issue - I've never allowed that and I've run into this problem twice in less than 5 months.
    ISM Data
    3622963000
    Host: 3.93
    SNS: 39.03
    WHR: 24.00.02
    BMX: 24.00.02
    SoftDevice: 7.00.02
    My alarms are fairly basic - I have a regular alarm 2 days a week, a smart alarm for 2 days, and another smart alarm for the remaining 3 days.  If I remember correctly, I had 2 or 3 additional alarms that were saved but turned off.
  • Thanks for the reports and attempted troubleshooting, all. Software version 3.93 for the Index Sleep Monitor is now available which should help. If you are continuing to experience syncing or pairing concerns, please create a new thread detailing what is happening.
    Regarding alarms, battery drain, or other concerns, please create separate threads for those so they can be organized and addressed accordingly.
