I bought an Edge Explorer in the UK with European maps. I am moving to the USA and want to change maps. I bought the NA map, but how to remove the European map to install it? There is not enough space for both.
I live in the USA and purchased the Europe Map to install and it states I don’t have enough room
I had to remove the USA maps, then install Europe maps. It worked, just got back from Europe.
Great, that is what I want to do. How?
I had this problem too and wasn't easy to find the answer but the solution IS easy.
You can do it using the Garmin Express app. So install the app on your computer and plug in your Explore and you can manage which maps are on your device using the app.
There is limited memory on the device so you might have to remove the existing map to add a different one.
