So if you want to use remote control then go back to v5.1. You will be penalized by deleting all data and settings. I have no words ... (I have but I want to be decent)
Although I do have to disactivate / activate my remote on the Explore each time I want to use it, apart from that it does work fine with 5.30
I must agree it is very disappointing Garmin hasn't fixed this issue introduced in 5.20. At least I hope the battery consumption is better now. But this remote issue is very annoying and unnecessary.
I reverted back to 5.10 during 5.20 was out, but somehow it installed 5.20 itself sometimes, even if rejected the installation all the time. I can't find the setting to not auto update like I have on my Fenix. If everything is working fine, I don't want to have it broken by a new update.
I don't get it - don't they test it? - and the bug has been known since v5.2. To prevent updates, you need to disable garmin express on your PC - automatic startup and running in the background. If you have run it, delete the GUPDATE.GCD file in the / garmin directory
don't they test it?
No, they don't.
