Hi,
e lost
My edge was updated yesterday to ver. 4.60. After update, i'v lost connection with my android and can't pair it again. Do you have any idea what is wron. I did everithing by a manual.
Thx
Janez
Hi,
e lost
Thx
Janez
I managed to pair the Edge Explore with my Android phone using Garmin Connect Mobile.
Hi,
I also using garmin connect Mobile. I didnt have any problems with 4.40 until now with 4.60. For now ver was downgraded back to 4.40.
Thy anyway
I had the same, ended up removing paired devices from Edge and my phone and pairing it again.
I had problems re-pairing my Pixel2 with my Edge Explore after updating to 4.60. I also changed the friendly name of my GPS at the same time. In the end I had to forget the Bluetooth connection with the GPS on my phone and then reconnect through Garmin Connect (on the phone) It seemed to take a long time (several minutes) and I think I had to repeat it before it connected. Mind you for some strange reason my Pixel2 still "knows" it by the old friendly name. Which suggests I would need to clear a cache on the phone to dissociate the old name from the GPS Bluetooth address.
What works in my case: remove Edge from Garmin connect and add the device again. After that syncing is possible again. First of all I did the Bluetooth pair action what was not enough.
I am having some issues and ia have to disconnect and reconnect every time to sync and to make iphone and garmin communicate again...
