I am using a Garmin Edge 840 with an Elite Direto XR.
The trainer is paired correctly as an ANT+ FE-C device (Fitness Equipment Control – trainer control protocol) and manual control works fine (I can set target power or resistance from the Edge).
However, during structured workouts (both created directly on the Edge and imported from TrainerDay), ERG mode stops working after some time (around 10 sec).
The trainer switches to resistance mode and power is no longer controlled, it’s extremely hard not possible to ride.
Important observation:
If I open TrainerDay (even paused), ERG control immediately works correctly again.
This suggests that the Edge 840 loses FE-C control (trainer control) during the workout.
Has anyone experienced similar behavior or found a workaround?
