I have a corrupt .FIT file that I'm not able to fix. I tried Garmin Online Fit Repair tool and it didn't work. Could anyone help mi repairing this file? Thank you very much in advance. 2021-03-20-09-51-54.fit.zip
I assume this was a ride, so I changed it to cycling. Also the device info was corrupt. I used a bogus serial number so your device would show up on Garmin Connect.
This will work - 2021-03-20-09-51-54-fixed.fit
Import into Garmin Connect using the [import data page] Repaired using Fit File Repair Tool.
Yeah! Great! Many thanks for your help!
