Good day. My 820 does not display the temperature correctly. The difference with the standard is about 5 °. It's linear. And in the cold and warm, the same 5 °. How the temperature reading can be calibrated.
It can't be calibrated. It is the temperature inside the unit at the baro sensor and does not accurately reflect external ambient temperature. Its primary purpose is to correct the baro sensor for its temperature dependence. As such it needs to measure the temp at the baro sensor, not external ambient temp. Displaying that temperature was an afterthought.
