On an Edge 810, is there any way to impose the speed and other info on top on the navigation map like I could on my Edge 800. Can't find where to set this anywhere. Not very intuitive software.
On the 800 it is: Menu / Settings / Bike Settings / Training Pages / Map (second from top). Here you can set the number of Data Fields (2 is the standard).
If you want to change the content of a Data Field just tap the field and hold your finger until the color changes to blue. Then you can select the content from the list of categories, etc.. I do not own an 810, but suppose to be quite similar to the 800. The 810 may have activity profiles like Road Cycling, Mountainbiking (Off-Road), Automobile, etc. and in that case the settings for the data-fields on the Map screen are to be set per profile separately.
Hope this helps?
