Hi, buy new garmin 820 in china, from aliexpress.com and problem is temperature -5ºC always and altimeter is 20 the 25.000m all time, never change temperature, all time -5ºC Activities are wrong, very wrong Need help
I've had this issue too and have been working with Garmin support. There can be problems if there are files on the device. They don't seem to know which ones cause the problem. Even a factory reset might not fix it, but there are other files you can remove in that case (like the saved activities.). It's frustrating. I was convinced it was a hardware issue until I deleted a few files this afternoon and it was working perfectly, for a few minutes, and then it happened again.
