Firmware version 32.20 for Edge 550 is now available. This update can be downloaded through Garmin Express or Garmin Connect Mobile when available.
Live for all users as of 8/20/26
Change log for 32.20:
- Added automatic climb/descent detection for Enduro/E-Enduro profiles as the default setting under MTB/CX.
- Improved the Bosch eBike metrics data screen.
- Improved the Stamina model.
- Fixed time-in-gear recording for Shimano 1x Di2 systems.
- Fixed a pairing issue with RearVue 820.
- Fixed an issue that showed an incorrect distance in postal code search.
- Fixed the Daily Suggested Workouts settings so they can be disabled from the home screen.
- Fixed an issue that caused course points to appear when disabled in course settings.
- Fixed ClimbPro indexing when starting a route partway through.
- Fixed incorrect grades in post-ride ClimbPro analysis.
- Improved the positioning of rider and Virtual Partner markers in zoomed elevation profiles on ClimbPro and Segment pages.
- Fixed incorrect trimmed time and distance shown at a provisional finish point.
- Fixed a crash during long activity recording with battery saver enabled.
- Improved incident visibility on the activity summary map.
- Removed trainer +/- controls while following a course or activity.
- Improved Gear Tracking behavior when no gear is selected.
- Improved device stability and fixed various minor bugs.
- Made general security improvements.
