I'm having issues again with latest update with gradient readings !!! Spikes of -8% and +8% everywhere !!! Absolute crazy. Have they F...k.... this again?
Since gradient readings are calculated using elevation data from the barometric altimeter, we recommend reviewing the following support article and checking the items outlined there that can affect the…
Thank you for your reply, but this is exactly the kind of copy-and-paste response Garmin has been posting for years whenever users report barometric or gradient issues.
Many of us have already cleaned…
Unfortunately, I had no choice but to send my Edge 540 back to Amazon's repair centre, as that was where I purchased it.
It's extremely frustrating to have to return a device for repair when all the…
Update: I did delete the advance grade(1) and set the default grade for garmin on my data screens, then I tested it and boom!!!, it is not accurate again.
So, I did an update check via wifi(which I normally…
I had the same issue, you have to erase the totals, doesn’t affect any of your stats or previous rides, just erase the totals then do like the on/off button restart ( hold it for like 10 seconds) it will turn off and turn back on and all will be all ok
