Edge 540 Series SW 31.29
Firmware version 31.29 for the Edge 540 Series is now available. This update can be downloaded through Garmin Express or Garmin Connect Mobile when available.
Live as of 5/22/26
Change log for 31.29:
  • Added Support for Bosch smart system eBikes.
  • Added support for gear tracking improvements.
  • Updated radar data screen to support the selected Color Mode instead of always displaying in dark mode.
  • Fixed some flat roads giving credit for climbs.
  • Fixed auto zoom while following a course.
  • Fixed Strava widget freezing on some devices.
  • Fixed ClimbPro page not showing grade/position correctly.
  • Fixed time in gear for shifters not showing in ride summary.
  • Fixed time in gear for Shimano eBike shifters.
  • Fixed crash during course navigation.
  • Fixed crash while searching for recent finds.
  • Fixed translation issue causing "Day" to be added to date strings.
  • Fixed elevation profile manual scale adjustments.
  • Fixed dew point and UV-index in weather widget.
  • Fixed crash using RTS to edit data screens.
  • Fixed crash on course list.
  • Fixed step goal being changed unexpectedly.
  • Fixed CIQ data fields causing UI lag/freeze. CIQ data fields will now start when you enter the timer loop or when an activity is started.
  • Fixed options menu while start/stop/pause overlay is present.
  • Fixed Daily Suggested Workouts showing on the main menu when toggled off.
  • Fixed shifter button actions for configurations with more than 4 available buttons.
  • Fixed map data field locked to track up orientation.
  • Fixed ClimbPro remaining climb distance on the edit page.
  • Fixed speed value on speed graphical data field.
  • Fixed contacts not displaying on remote widget for inReach mini 2.
  • Fixed workout schedule showing only rest days after modifying target type.
  • Fixed label alignment on the timer overlay.
  • Fixed battery icon on the status bar page.
  • Fixed slow syncing over wifi.
  • Rearvue 820 Radar Display: Removed Warning Icons from orange level threats.
  • General improvements to device stability and addressed various minor bugs
