Hello, my new Edge 530 is not displaying the local time. I assumed it would be updated after syncing with Connect. But that didn't happen.
Any idea how to fix this?
Thanks
Thanks
same problem
Make sure the device is set to an outdoor profile (road or mtb), take it outside and let it get a GPS lock. This may take a while if it hasn't had one before. Once it knows where it is it will update…
If you install the beta release then it will pull the time from wither your WiFi or Phone connection. The current public release requires you to get a GPS fix.
Also check that you have the latest time…
Also check that you have the latest time zone map installed. There was new release recently.
Could be you try re-installing the GPS software by placing this file in the Garmin\RemoteSW folder on the Edge.
Make sure it is named 006B310700.GCD. The uploading process looks like it might have changed the name.
