I have a Edge 520 that only powers on when plugged into a USB port or electrical outlet, could this be a battery issue ?
It’s most likely to be a failed battery. I’m assuming it otherwise works normally and shuts down as soon as the power source is removed.
It’s not surprising given the age of 520’s now.
Thank You, Yes it works normally and shuts down as soon as the power source is removed.
