hi - my Garmin 520 will simply not stay switched on
it keeps switching itself off
I can see there is a red cross in the left hand corner
it does turn on but only for approx 5 seconds then it switched itself off
please help? thank you
That will depend on what other troubleshooting steps you’ve taken. If it doesn’t respond to an external power source, it appears that no power is going into the device. Try a different cable to eliminate that as an issue.
Does your computer recognize it as a USB device? If yes then it’s not the cable and try cleaning out old activities and courses to make sure there is storage space available
Have you tried a device reset?
If nothing works it’s starting to look like some other hardware issue which is bad news.
